How to Delete Binaural beat in a file ?
Hi :slight_smile:
First i want to apologize if my english is not the best…
So…
I downloaded a hypnosis but in the song there are the voice of the girl and a binaraul beat
In fact the binaraul beat bothers me so i want to remove them
Serching on google i download load of stuff for remove this but no one work… and i found some topic here where people have the same question to me but follow the step and nothing work for me…
I was like using the spectrogramm and notch filter but no one work with me , still have this binaraul …
If someone can help me …
Please explain me like a total noob i’m so confused :frowning:
Thanks you and have a nice day :mrgreen:
Audacity can’t take a song apart into individual instruments or voices. So we can’t split off drums, rhythm or beats and make the volume higher or lower.
Did you try Effect > Vocal Reduction and Isolation? Sometimes you can use that to change an instrument or rhythm instead of a voice. Try to isolate the voice instead of lowering the beat.
http://manual.audacityteam.org/man/vocal_reduction_and_isolation.html
If that does not work, then you may be stuck with the beat.
Hi
yes i do this
there is no nore binaural but the voice is like whispering
so i put gain to the max and it’s understandable
Not perfect but there is finally no binaraul… guess it’s ok then
I take 4 hours testing lots of stuff
but finally with only one post here i finally reach my goal
Well…
Thanks you man i appreicate your help ! :mrgreen:
Bianural Beats are created by ‘interference’ between the left and right channels, so the solution is simple:
Step 1:
Split the track into two mono tracks (see: http://manual.audacityteam.org/man/splitting_and_joining_stereo_tracks.html)
Step 2:
Delete one of the tracks.
That’s all.
