How to convert MP3 / AAC to FLAC with quality increase?
I don’t have one, and you may need different settings from those shown - you will need to experiment for best results.
Thank you very much, now how do I get these effects?
– Bringing up the low bass
– Bringing up the high treble so it’s easier to hear the vocals/guitars
– Zooming in slightly to help fill out the frame
– Processing with analog, multi-band compressors to preserve the vintage sound
Then?
Read the documentation: http://manual.audacityteam.org/man/equalization.html
you can’t increase audio quality by converting them to flac, I think it will somewhat damage the quality
It’s true that you can’t improve the quality by converting to another format, but FLAC is a lossless format, so it will not damage the quality.
By the way, this topic is over 3 years old, and the original poster has not visited this forum in over 3 years.
You can convert/record the files with lossless quality by using Audacity, FFmpeg, DumpMedia Video Converter, and Audio Converter. They are useful software.
It is not possible to convert files with a quality increase.
This topic is over 4 years old, and the original poster has not visited this forum in over 4 years.
