How to change the lyric of songs using the same artist voice
i have listen to some songs and parodies that change the song lyrics and seams like the singer is really singing those words.Some parodies replace the singer voice and the lyric but what i want is to make the artist sing other things in the song with the same voice.Some one told me audacity can do that but i don’t know how to do it please help.
Stop listening to that person.
A very common request is to make a voice into a different voice. We’re not up to it. Koz
then, how can i do that? i know is possible cause i have hear it…the main idea is to sing and change parts of the song lyrics and that the voice at least have a resemble of the artist voice…i thought strip the artist voice then i sing the lyric i want but i need something to change my voice very much alike the original artist voice and sinc it all together but once again,how can i do that?
Usually, everything in a parody is re-created. Skilled musicians re-create the music. (The same thing is done with Karaoke songs, because “vocal remover” effects are not good enough.) Then, and a skilled singer mimics the original voice.
I have done this VERY LIMITED for my daughter. I have only used the vocals & words that presently exist in the song. I copy a word and paste it in place of the word I want to change. Sometimes you can get suprising results by simply ‘cutting’ out a word. This method is not DEFINITLY NOT ‘seemless’, and can no way replace an actual ‘remix’ with new vocals, but it can have very fun results! Strictly ‘shadetree mechanic’ type of stuff. If you want studio results you may need to record a new performance with your lyrics.
Not legit to post it on t’internet …
Just answering the persons question.
Know this thread is old, but this is a lot more doable now with current tech.
And you could use audacity as your editor.
You can follow the steps in this tutorial if you want to DIY, but you can also order custom lyric swaps from my site as well
