How to Automate Equal Distance?
Hello,
Does anyone know how to automate equal distance between each sound. Like if you have different sound bytes. Put them into one section, but not merge them. I just need to be able to put like different sound bytes together with equal distance of time between them. I need it to be at least .5 seconds between each byte. Any help would be appreciated.
If the clips are on separate tracks, perhaps you could Tracks > Align Tracks > Align End to End, Tracks > Mix and Render to put them in one track, then search for a plugin to suit your purpose.
If the clips are of equal length, you could try Regular interval audio splitter.
If there are silences at the end or start of the clips, you could try Extend Silences.
Those are both Nyquist plugins - see here for how to install Nyquist plugins: http://manual.audacityteam.org/o/man/effect_menu.html#nyquist_effects.
