I am using Audacity to convert cassette recordings into mp3s. My problem is that the right channel is a little lower in volume than the left. I can’t figure out how to increase the right channel volume, or decrease the left. I want them to be equal, but I can’t seem to be able to adjust the volume on each channel. When listening to the tape coming directly through headphones from the cassette player, the balance is fine.
Using a small cassette player with a USB connection to my computer. Brand is “Reshow”, purchased on Amazon. Looks like an old Walkman, but with the USB line out.
mp3s. My problem is that the right channel is a little lower in volume than the left…
…When listening to the tape coming directly through headphones from the cassette player, the balance is fine.
Now, that’s weird. How much difference is there? Are you actually hearing the difference in the digital file or are you just seeing it?
A small difference isn’t unusual for analog (there are lots of imperfections in analog) but a big difference could indicate a different-bigger problem.
You can’t adjust the balance while recording but you can adjust it after digitizing. If you [u]Split Stereo File[/u] you can select & edit/process the channels independently.
Select one channel at a time and run the [u]Loudness Normalization Effect[/u] and adjust the “perceived loudness” the same value on both channels. At this point it doesn’t matter what you set the loudness to, just make them match. The peaks may be different but that’s OK. You want to match the overall “average” loudness. And if you see clipping (red) don’t worry. We are going to fix that next.
Select [u]Make Stereo Track[/u] to re-link both channels again. (You may have to Select → None to make that option show-up.)
Run the Amplify (or Normalize) effect to bring the peaks up (or down) to 0dB, and you’re done!
…There is an option to Normalize the left & right channels independently. That’s just one step to make the peaks the same in both channels (so you don’t have to split to stereo, etc.). But it doesn’t work as well for perceived loudness matching.
I can, and do, on my machine → right click the speaker near the clock, choose “Recording devices”, pick the line in, get Properties on it, click the Levels tab, click the Balance button
(This is Windows 7 btw)
I don’t know if this is someting that has to be “supported by the sound card”
What DVDdoug was referring to, is that Audacity does not provide any facility for adjusting the balance (or any other effect) during recording. The way that I would adjust the balance would be via the mixing desk that is connected to my computer, but that really doesn’t have anything to do with Audacity.
