Hello.
How to add silence at the end to many files?
I tried macro - not working.
After several hours I found how set cursor at the end:
Screenshot - https://directory.audio/images/monopics/2025-02-06_00-50-57.jpg
Then, I used Silence and Silence Audio commands - and audio files are empty after that.
Or, I’m getting message - That silence requries some tracks should be selected.
It works OK for me. This adds 2 seconds of silence to the end of the project and exports as WAV.
SelectTime:End="-2" RelativeTo="ProjectEnd" Start="0"
Silence:Use_Preset="<Current Settings>"
ExportWav:
Note that the end time is “negative”, meaning that it is outside of the selection.
