Hello,
I was wondering if it was possible to add a bone conduction filter into audacity, or a way to create a makeshift version.
Thank you in advance
Hello,
Currently Bass and treble is Audcaity’s only real-time native equalization effect, (srsly).
There are native equalizer effects, but they do not work in real-time.
https://manual.audacityteam.org/man/graphic_eq.html
https://manual.audacityteam.org/man/filter_curve_eq.html
If you want a real-time equalizer you’ll have to install a plugin into Audcaity,
e.g. https://www.voxengo.com/product/marvelgeq/ (free).
