I have over 2000 tracks I want to add a second of silence to. I know how to create the 1 second of silence to all the tracks but I’m having problems with aligning them with the end of each track before exporting them all out into their own files.
How do I create a second of silence and align it to the end of each track?
Moderator note: Please do not double post - unfortunately we have to moderate posts on the forum to avert a flood of spam some of which is unpleasant and some downright dangerous. We do have moderators scattered around the various timezones of the world so it doesn’t usually take long for a post to be approved.
Do you accept that if the tracks are all different lengths before you add the silence, they will still be different lengths after adding the silence?
If so the best way is to click in each track, press K on the keyboard to move to the end of that track, then generate 1 second of silence. That silence will be selected, so CTRL + C to copy it.
Then repeat the steps for the next track, but after K, just CTRL + V to paste.
It’s probably easier to automate this about 200 files at a time by downloading TrimExtend.ny . To install TrimExtend, put it into the Plug-Ins folder inside the Audacity installation folder, then restart Audacity.
Then use File > Edit Chains to create a Chain containing TrimExtend followed by an Export command.
Then use File > Apply Chain to apply the chain you created to multiple files.
Note - don’t apply the Chain to all 2000 files at once - that is outside the current capability.
