Maybe you already have help. Do you use Skype, Zoom, Google Meat, or Multi-Player Games? These applications take over your sound services. Sometimes even if you shut them down, they can leave some of their adjustments running in the background.
Try a Clean Shutdown.
That’s where you tell the machine to shut down and not leave anything running. It takes a bit longer, but it can give you a more stable machine.
thanks for speedy reply but I don’t use any of those websites / apps.
I have a clean Win 11 and Audacity just cannot adjust recording audio levels.
I am looking for another program that can actually adjust recording levels.
I think Adobe Audition can do it.
Hi Koz, me again. I just wanted to say you were on the right track with your answer above.
I have a USB audio device plugged into my PC and I listen through headphones. I have nothing plugged into the audio jacks on my PC. I did a google and this means there is no onboard audio to control.
So I plugged some cheap Dell speakers in & its working as expected. Thanks Koz.
