How do I update Audacity 3.3 for Mac Ventura 13.5.2
This is a rookie question and I apologize if it’s already been asked. I just installed 3.3 and when I try to run it I get a pop up telling me Audacity needs to be updated. For the life of me I can’t find how to check for updates. I’ve spent the last 2 hours trying to find out how. Please help.
Windows guy here. On Windows, it is possible to have two different copies of Audacity installed. The solution (at least on Windows) is to uninstall the software (more than once as necessary), then reinstall. You many also need to terminate the currently running copy. If your machine is locked up for some reason, this may require rebooting.
Help > About Audacity will show you what version is currently running.
You can download the current version of Audacity for Mac here: Mac | Audacity ®. The current release of Audacity is 3.3.3.
Thanks for the reply. You gave me some ideas. Much appreciated.
