How do I get the same volume on this recording?
Is there any way to make the recording sound better?
Do you want to make the loud and quiet parts about the same?
Try the Limiter effect.
I’m not sure what you mean by “sound better”. The is some background noise during the quiet-talking parts, and that’s going to sound worse if you make those parts (relatively) louder.
…It’s the kind of noise you usually can’t remove but you can try Noise Suppression.
Yes.
I use Dolby On when I record with my internal Android microphone.
