How do I Find a tracks LUFS level?
And what would the standard be for a trance/hard trance track that is compressed be?
Many Thanks,
Karl.
Many Thanks,
Karl.
You can normalize the audio to whatever LUFS level you want: https://manual.audacityteam.org/man/loudness_normalization.html
Probably as high as you can get it, though if it is played on a professional broadcast it will be reduced to whatever standard the broadcaster uses.
Thanks Steve,
Don’t want it to be distorted so wasn’t sure
[u]dpMeter 4[/u] works in Audacity.
To prevent [u]clipping[/u] keep your peaks to 0dB or less.
After running Loudness Normalization and before exporting, run the Amplify effect. Audacity already knows your peak level and Amplify will default to whatever change is needed for 0dB peaks.
For example, if Amplify defaults to -3dB your peaks are currently +3dB and you have (potential*) clipping. Running Amplify will reduce the volume bringing your peaks down to 0dB so you won’t get clipping. Of course, this will also bring your LUFS level down by 3dB.
If Amplify defaults to a positive level you can cancel the Amplify effect or go-ahead and Amplify.
