How can I upload a podcast in Audacity?
Hello people, I’m Emmanuel Katto from Uganda. I wanted to upload a podcast of mine in Audacity, can anyone help me with this?
You need to create an account with audio.com
You can also save the audio file as a mp3.
Sign up with Spotify for podcasters, (free). You will be given your personal RSS Feed to distribute your show on platforms like Apple, Google and many others.
Thanks for your answer.
hello,
How can I upload a podcast using Audacity? I’m new to podcasting and would appreciate any step-by-step guidance or tips on how to get started with uploading my content. Also, any recommendations for tools or platforms to enhance my podcasting workflow would be great!"
For more insights on podcasting and the latest tech trends, check out [links deleted] for more podcast resources.
An easy/free way to do it is go to anchor.fm (now called Spotify for Podcasters, but the URL will get you there) to distribute your podcast. You will need to export your file from Audacity to upload it. Mp3 is the most popular format for podcasts.
thanks for your post :+1:
can we not create directly like we do on spotify, ihearts, podaddict i am looking for my site [link delete5].
depending upon what equipment you are using, the mic on a laptop does work, hit record. I put in MP3’s by drag and drop, I use a separate track for music, and one for announcing, and then scootch the tracks up against one another to edit them together, and eliminate the gaps. I use a Shure mic, into a mixer which has a USB output into my laptop, or a Yeti mic has a USB plug, must be first set up in “control panel” of system, and then your Audacity session will also recognize that as a source. Been doing this since about 2006, have 1,000+ uploads on archive.org, as “DJ Shy John”
Hope this helps you, brother!!
