How can I tell ASIO is compiled in correctly?
I’ve followed the instructions (thank fully they’re there), and it all compiles normally… However, I cannot tell if the support is built in or not…
My build machine and the machine connected to the ASIO board are not the same… so is there anything I can do before taking the new compiled version to the new machine to make sure it’s there? Or do I just have to go on faith?
Thanks!
So if you click on Audio Setup > Host, ASIO will appear as an option.
Found it, once the software was installed on the same computer that is connected to the board… I guess there is no other way… Would be lovely if in the build information it could show the options that are compiled in…
But as of now, it’s working! Thanks to all!
