Hello !
I’m working on a project and I need to cut every peaks above 10 000 hz. kind of like on the pic here. Do you know what tool I should use ?
Thanks a lot, have a great day ![]()
Hello !
The “Equalization” effect can remove frequencies above 10,000 Hz.
(see: https://manual.audacityteam.org/man/equalization.html)
Just interested - why do you want to do this?
Thanks !!!
I’m musicotherapist and I work with acouphenic personns. I need to smooth the high frequencies that can be aggressive for them when they “peak”, but I still need to keep them high. Don’t know if that was clear lol
I’m french : sorry ^^
Ok… I just answered but I can’t find my answer : I guess it needs to be validated before?
Anyway, thanks if my answer doesn’t appear ^^
Anyway I can’t achieve what I need to do : it’s the “peaks” that I’m trying to smooth. Note the “high”
Is it more compréhensible said like that ? ^^
Multi-band dynamic-range-compression can attenuate any (bands of) frequencies which go above a volume-threshold.
There are many free multi-band compressor plugins for Windows which work in Audacity, (I don’t speak Mac).
A free plugin specifically for Audacity called Paul-L’s de-esser can be used as a multi-band limiter,
that may do the job for you, but it’s not simple to use …
Apple provides an Audio Unit multi-band compressor. The enable it, see this page in the manual. It is called “AUMultibandCompressor”.
– Bill
Thanks a lot for your time and answers ! I’m gonna try that ![]()
Have a great day !
