Recording a Epiphone Les Paul through a Fender Mustang II amp through it’s USB cable through Audicity, but everything just sounds so “hollow” (and quiet). I have the ASIO Fender drivers installed also.
Surely it must just be a setting or something that I’m doing wrong. Here’s a short clip that may help someone identify the problem.
Does the Fuse software let you record or is it just a way of controlling the Fender from the computer?
Are you on Windows, if so, what version? Does Windows Sound Recorder record the same kind of sound (click the Windows globe and search for “Sound Recorder” (without quotes) ).
