OK, I’m not a complete noob when it comes to computers as I once worked in IT, but I cannot figure this out.
I am trying to copy the noisegate.ny (or whatever it is called) into the appropriate directory. Memory says library>application support>audacity (don’t hold me to that).
I am currently on a computer where I have admin rights.
I am not able to find any of these files on the hard drive, other than the .app file itself.
I’m not a mac pro, used to only use windows, but in general if I have admin rights to the machine I should be able to see all files, no?
I’ve also gone into settings and asked it to “show all files” or whatever the option actually says.
What am I missing here? I feel like it’s so simple I’m going to kick myself, but google is no help.
Thanks all!
If you’re at a foreign machine, make sure nobody turned filename extensions off.
Desktop > Finder > Preferences > Advanced > Show all filenames.
Then make sure you really got a Nyquist file and not the TXT version of the Nyquist file.
You may be in the wrong Library.
Go (upper toolbar) > Go To Folder.
Now go to the audacity folder (lower case) > Plugins.
Even after you do all that, you need to launch Audacity and Effects > Add Remove Plugins
See attached. I’m admin, did the steps you’d described already, and here is the only item in the folder you directed me to (that I was using earlier as well).
Am I crazy?
And thanks for your help!
Am I crazy?
No. You didn’t follow instructions. The library you want is hidden and you have to reach it by the method I illustrated.
I think you can also reach it via the terminal/command line if you’re really into pain.
Last login: Mon May 7 11:41:34 on console
lucille:~ koz$ pwd
/Users/koz
lucille:~ koz$ ls
Applications Documents Library Music Public
Desktop Downloads Movies Pictures
lucille:~ koz$ cd Library/
lucille:Library koz$ ls
Accounts Fonts Safari
Application Scripts Group Containers Saved Application State
Application Support IdentityServices Screen Savers
Assistants Input Methods Services
Audio Internet Plug-Ins Sounds
Caches Keyboard Layouts Spelling
Calendars Keychains StickiesDatabase
ColorPickers LanguageModeling Suggestions
ColorSync LaunchAgents SyncedPreferences
Colors Logs Voices
Compositions Mail WebKit
Containers Messages com.apple.nsurlsessiond
Cookies Metadata iMovie
CoreData PreferencePanes iTunes
Dictionaries Preferences openvpn
Favorites Printers
FontCollections PubSub
lucille:Library koz$ cd Application\ Support/
lucille:Application Support koz$ ls
AddressBook Mozilla
Adobe Preview
App Store Quick Look
CallHistoryDB SyncServices
CallHistoryTransactions Tunnelblick
CloudDocs audacity
Console com.apple.TCC
CrashReporter com.apple.sharedfilelist
DVD Player com.apple.spotlight
Dock com.apple.spotlight.Shortcuts
Firefox icdd
MobileSync
lucille:Application Support koz$ pwd
/Users/koz/Library/Application Support
lucille:Application Support koz$ ls -al
total 32
drwx------+ 26 koz staff 884 May 2 17:29 .
drwx------@ 53 koz staff 1802 Nov 12 16:04 ..
-rw-r--r--@ 1 koz staff 8196 Apr 27 13:54 .DS_Store
drwx------ 10 koz staff 340 Feb 21 2016 AddressBook
drwxr-xr-x 22 koz staff 748 Apr 11 09:17 Adobe
drwxr-xr-x 3 koz staff 102 May 7 11:41 App Store
drwxr-xr-x 6 koz staff 204 May 7 11:41 CallHistoryDB
drwxr-xr-x 3 koz staff 102 Feb 21 2016 CallHistoryTransactions
drwxr-xr-x 2 koz staff 68 Feb 21 2016 CloudDocs
drwxr-xr-x 3 koz staff 102 Jan 12 2017 Console
drwx------ 11 koz staff 374 May 7 21:42 CrashReporter
drwxr-xr-x 3 koz staff 102 Aug 20 2016 DVD Player
drwxr-xr-x 3 koz staff 102 Oct 31 2017 Dock
drwx------ 6 koz staff 204 Jun 17 2017 Firefox
drwxr-xr-x 3 koz staff 102 Apr 11 2016 MobileSync
drwx------ 3 koz staff 102 Feb 27 2016 Mozilla
drwxr-xr-x 2 koz staff 68 Mar 3 2016 Preview
drwxr-xr-x 5 koz staff 170 Feb 21 2016 Quick Look
drwx------ 3 koz staff 102 Apr 11 2016 SyncServices
drwxr-x--- 5 koz admin 170 Apr 29 2017 Tunnelblick
drwxr-xr-x 11 koz staff 374 May 7 14:35 audacity
drwx------ 3 koz staff 102 Mar 6 14:51 com.apple.TCC
drwxr-xr-x 8 koz staff 272 May 7 22:02 com.apple.sharedfilelist
drwxr-xr-x 3 koz staff 102 May 7 10:06 com.apple.spotlight
-rw-r--r-- 1 koz staff 1988 May 2 17:29 com.apple.spotlight.Shortcuts
drwx------ 3 koz staff 102 Apr 18 10:55 icdd
I don’t know what to tell you koz, the “Go To” method brought me to the same place as my screenshot.
That can happen if you leave off the tilde (~) at the beginning of the address. That’s a UNIX abbreviation.
Mods can close this thread as needed, my brain omitted the ~ symbol, which was the problem
That’s never happened to me.
