template<int channels=8>
struct MultiChannelFeedback {
using Array = std::array<double, channels>;
double delayMs = 150;
double decayGain = 0.85;
std::array<int, channels> delaySamples;
std::array<Delay, channels> delays;
void configure(double sampleRate) {
double delaySamplesBase = delayMs*0.001*sampleRate;
for (int c = 0; c < channels; ++c) {
// Distribute delay times exponentially between delayMs and 2*delayMs
double r = c*1.0/channels;
delaySamples[c] = std::pow(2, r)*delaySamplesBase;
delays[c].resize(delaySamples[c] + 1);
delays[c].reset();
Array process(Array input) {
Array delayed;
delayed[c] = delays[c].read(delaySamples[c]);
double sum = input[c] + delayed[c]*decayGain;
delays[c].write(sum);
return delayed;
Hi, I’m trying to implement the same code but in Nyquist.
I am trying to use snd-delay for the feedbacks.
I’m reading the tutorial from here: Let's Write A Reverb : Blog : Signalsmith Audio
I’m confused on how to exponentially distribute the delay times.
Is there any advice anyone can give me?
Thanks,
24ElijahH
