Just downloaded the full package of Audacity for Mac (OS 10.12) which should come with the local help file and manual. I have a folder at the root level called Help, which contains a folder called Manual but can’t access this within the program. It keeps telling me I don’t have it installed.
Any ideas appreciated.
Thanks for your response but this didn’t seem to work.
I reinstalled Audacity according to your instructions, but it still says I haven’t installed the help file or manual
You can see an image of my files and folder setup here: https://www.dropbox.com/s/sqc28nk1cvim3sl/audacityfiles.jpg?dl=0
Thanks
Have you tried rebooting the mac?
Is anything else missing in Audacity? For example do you have Generate > Click Track… ?
If reboot does not help, try right-click or CONTROL-click over Audacity.app, click “Show Package Contents”, expand the “Contents” and “MacOS” folders then double-click the “Audacity” file. Note that this opens a Terminal window which you will have to close after quitting Audacity.
