Hi! Did someone knows how to make this FM Sound Effect into MP3 on Audacity? I tried to found some mods and it doesn’t sound like what I want.
Example: https://drive.google.com/file/d/1fKUXiyr-EIfvh0uPWWx--ltNot5ohGAJ/view?usp=sharing
Do you mean: “What effects are used in this sample?”
The most obvious effect is AutoTune (see “Cher effect”).
Autotune does not support Audacity.
See also this topic: https://forum.audacityteam.org/t/what-effect-is-this/27053/1
The full ($30) version of Grallion2 plugin has pitch-correction (i.e. autotune), and modulation effects
https://www.auburnsounds.com/products/Graillon.html
Try the free version in Audcaity first before you buy, to see if you can get it to work.
Another solution would be the standalone* version of O-Vox ($40-$75)…
https://youtu.be/CLMOzVcDlQE
Again try free demo version before you buy.
[ * O-Vox won’t work in Audacity, Grallion2 will ]
@steve I tried this solution, but it doesn’t work
@Trebor It doesn’t work.
I will try the second solution, @Trebor
@steve It works.
But now how do I try to sound like that example using GSnap?
Unless you’re using the 64-bit version of Audacity, you’ll need the old 32-bit version of Grallion2
https ://www. auburnsounds.com/faq/Where-may-I-find-older-versions.html
“Graillon-FE-2.2.zip” (not the VST3 version)
Ok. I will try.
“Graillon-FE-2.2.zip” (not the VST3 version)Ok. I will try.
It doesn’t work. Again. And yes, I used the old 32-bit version of Grallion2
It doesn’t work. Again …
Works for me …
BTW none of your Google-drive images are visible, (you haven’t given permission for others to see them).
Works for me …
I will try to reinstall Audacity, and then, i will retry to put Grallion2 32-bit version.
Works for me …
It works. Now, how do I make that FM sound effect using Grallion2?
The free version of Grallion2 just does pitch-correction, which can be adjusted to the “Cher” effect …
You have to pay for the full version to enable the modulation effects …
Again your images not visible to anyone other than you.
There is a permission within google-drive to allow others to see them: “anyone with a link”.
https://youtu.be/TH1qhJR_ous?t=409
https://youtu.be/u-iyuK_mmXs?t=297Again your images not visible to anyone other than you.
- I don’t have money to pay this.
- Next time, I don’t post the images, if you say that my images is not visibile.
… I don’t have money to pay this …
There are free Audacity plugins for Tremolo/vibrato, ring-modulation & bitcrush.
Apply them after the Grallion2 pitch-correction. IMO that’s the closest you can get for free.
I will try!
I tried your solution and it doesn’t sounds like what I want.
The “Na-na-heh” bit has pitch-correction and ADT which is the female voice is shifted down an octave.
The free version of Grallion2 can do both of those at the same time …
