HELLO please i have spent half the day trying to find the prject i recorded last night and finally have but its not where it was meant to be in temp 1_2 but the other audacity file has all the au files but the recovery tool wont peace them together and im left with loads of files and folders the recording is around 4 hours long and i have no idea where to tern or what to do im pretty buggerd with out that recording any help please please let me no its all there just dont no how to peace it all together when Audacity Recovery Utility all i get is a error message saying there is no audio files in the location when inface there is please please please help someone !!! also when i try and use the audasity recover it says ERROR NOT WELL FORMED INVALED TOKEN AT LINE 21859 PLEASE HELP ME OR MY BOSS WILL KILL ME thank you jeb pleace
Did you save this project? If so the data will be in the _data folder that has the same name as the AUP file.
Did Audacity crash?
Look in Help > About Audacity. What are the three numbers for version number? If you are using Audacity 1.2 you should to upgrade to 2.0.5 from here http://audacityteam.org/download/windows .
What version of Windows?
The AU files are in a folder, not a file.
Please answer the questions above, and attach the AUP file. Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1 .
If you don’t have an AUP file (you never saved the project) then I assume the line error is in the AUTOSAVE file and you are actually using a 1.3 or 2.0.x version of Audacity. In that case, please attach the AUTOSAVE file.
The AUTOSAVE file is at Documents and SettingsApplication DataAudacityAutoSave on Windows 2000 and XP or at UsersAppDataRoamingAudacityAutoSave on Windows Vista, Windows 7 and Windows 8.
To find the AUTOSAVE file you will need to show hidden files and folders. Click this link to find out how to do that for your version of Windows: http://www.bleepingcomputer.com/tutorials/how-to-see-hidden-files-in-windows/ .
