Help, can you fade in 2 audios?
Can fade in 2 audios be performed? and Also fader in and out from the audio?
dejo ejemplo aqui…
fader
In future update will that option be added?
fundido
crossfade clips & crossfade tracks.
Thank you. but the option does not appear in what the manual says, I say it is to merge 2 audios or to be able to have control in the crossfader curve in the multitrack as I put in the reference option.
