[help] about channels
I have the acapella/vocals and the instrumental. I want the acapella/vocals to be in the left channel and the instrumental to the right channel. How can i do that?
I heard it is called Split Channel?
What does that mean? You’re all ready to sing and play the piano?
If you have already imported your recordings into Audacity and now have two stereo pairs of tracks: one carrying the vocals and the other carrying the instrumentals, use the pan slider in the track details panel (at the left end of the tracks) to place the sounds to where you want them on the stereo sound stage. Note that, conventionally, the top channel of the stereo pair is Left and the bottom is Right.
If you do not yet have your recordings made - listen to Koz
