Hearing "muffled" audio on Audacity while Direct Monitoring using Focusrite Scarlett 2i2 with headphones
Receiving ”muffled” audio interference using Direct Monitoring during recording Mono audio using AUDACITY 3.7.7 and Focusrite Scarlett 2i2 interface with headphones for monitoring audio.
Any recommendations on how to eliminate “muffled” interference in Direct Monitoring of Mono audio?
“Audio enhancements” can cause muffled recordings …
https://support.microsoft.com/en-gb/topic/disable-audio-enhancements
Direct monitoring doesn’t go through the computer.
If it’s a directional “studio” microphone, make sure it’s pointed in the right direction.
Trebor:
Yes, indeed, Audio Enhancements MUST BE TURNED OFF from ALL input devices (mics, Realtek, interfaces, etc) in order to eliminate “muffled” audio during Direct Monitoring, using headphones.
But, this ADVANCED function is buried DEEP INSIDE:
SETTINGS-> SYSTEM → SOUND → INPUT → DEVICES-> ADVANCED :roll_eyes:. GOOD LUCK!
Thank you for the pointer. I would not have found it without considerable hunting for a needle in the haystack! :roll_eyes:
AMITAVA MUKERJEE
