I cannot get Audacity to play on headphones. They are plug in but blue tooth acting the same . Only plays on computer speakers. All other sound programs play on the headphones.
After connecting your headphones, try Transport > Rescan Audio Devices, then under Audio Setup, select your Playback Device.
GOT IT, THANKS!! I had two tech helps not find or know that fix.
