Having trouble with down load of asio4all drivers for audacity on windows 11
When I go to download asio4all it is loaded with adds and if I can get it to download it will not work on my computer.
Note that Audacity doesn’t support ASIO (1) and ASIO4ALL only adapts-translates Windows hardware drivers. It won’t help if the application doesn’t support ASIO.
Yeah… Lots of tricky ads on that page!
Go to Overview → Download . Then find and click ASIO4ALL 2.16 Multi Language.
That should give you the install file ASIO4ALL_2_16.EXE.
(1) If you are programmer or “serious hacker” you can compile Audacity with ASIO support. There is some information here. I’ve done quite a bit of on-and-off programming over the years but Audacity is a BIG complicated project and it’s not something I’ve ever attempted.
Hey, thanks a lot. I will give that a try.
