Running Windows pro version 5.1 on Dell E520 and using Audacity 2.0.6 installed from .exe.
Sound card is SigmaTel High Definition Audio CODEC.
Mixer device shows as SigmaTel Audio and Recording shows: only Line In, Rear Mic, and Microphone. Playback shows: Volume Control, Wave, SW Synth, CD Player, and Input Monitor.
I can’t create a configuration that will allow me to record streaming audio.
Some time ago I used Freecorder, which worked fine at the time, so, I know it’s possible to do, but how with Audacity?
It’s not a typing error. It’s 5.1 with Service Pack 3, pre-WASPI.
Another point, I did clean the drives and reloaded the OS between Freecorder and now.
Would WASPI work with 5.1?
If you reinstalled Windows then you should reinstall the audio device either using the drivers CD the computer came with, or by going to the Dell web site and downloading the correct drivers.
If you read the link Steve gave Audacity Manual you can see that WASAPI recording is not available for XP.
If you don’t get stereo mix or what U hear devices after installing the correct audio drivers then as described on the above page you can run a cable from audio out to line-in and record the line-in.
