I’m having a problem with Audacity versions 3 and 4 not receiving the audio signal from a Behringer UMC204HD digital audio interface box. I am trying to record the analog output from a stereo preamplifier which is directed into the Behringer interface box which has a USB cable output. The Behringer box is receiving the audio signal, as indicated by the LED audio level indicators being activated when audio signal is going into the interface box and headphone output of the box produces a good signal. Audacity lists the Behringer UMC204HD as the recording device. I consulted both Google and Bing AI on this problem, but their suggestions did not help. I tried changing the Audio host setting in the Audacity audio settings options from MME to all the other possible settings, but this did not work. I verified that the Windows (using Windows 11) audio sampling rate of 48000 Hz matches that of Audacity. Any suggestions of how to solve this problem?
Windows 11 has a privacy setting : apps, like Audacity, have to be permitted to have access to a microphone, (your USB audio interface could be a mic).
Problem was solved by suggestion from Trebor to uncheck the boxes for the exclusive mode for the USB audio interface in the Windows Sound settings.
