Hi, I tried many times to enable the GSnap plug-in for autotune vocal modulations on the new 2.3.0 version, but it’s not working: it always returns to the disabled button. It crashed also on the previous version and it seems a difficult effect to use. Please fix the issue - thanks.
Ensure that you have the 32-bit version of GSnap (even if you have 64-bit Windows).
Thanks for your prompt reply, yes I have THAT version: nothing happens, sorry about that. I think it’s a major issue: any other idea?
