I am running audacity 2.1.3 on windows 10 64-bit, and I am trying to use the plugin in gsnap to change my vocals just slightly but that right there is the problem it doesn’t change anything. It shows up in my plugins I can open and use it but it simply just doesn’t have any effects on my actual vocals does anyone know a fix to this? Thanks in advance
The free version of Grallion2 plugin has pitch-correction. Its interface is easier than g-snap.
Alright ill definitely try using this. Thank you.
