Group tracks in Audacity 2.3.2
I work with Audacity 2.3.2
I’ve got two tracks that are basically 2 parts of the same verse.
Track 1
Track 2
What I want to do is to group them, so they make one track on one line.
Track 1-2
The current version of Audacity is 2.4.2. It is available via the Audacity website: https://www.audacityteam.org/download/windows/
Audacity doesn’t have “track groups”, but you can “mix” tracks: https://manual.audacityteam.org/man/tracks_menu_mix.html
You can also change the waveform color of some of the tracks: https://manual.audacityteam.org/man/audio_track_dropdown_menu.html#colors
4l3xb34st,
I’m not sure exactly what you are looking for, but you could try “Select->All” (Ctrl-A), “Tracks->Align Tracks->Align End To End”, then “Tracks->Mix->Mix And Render”. Also, see this post:
https://forum.audacityteam.org/t/join-multiple-files-into-one/59152/3
