Greetings! I have High Sierra (10.13.6) with Audacity 2.3.3. Installed the free Graillon 2 Equalizer (AU) in Components and Enabled. When I apply the effect to a track, I get only a gray box with three transport buttons and an Apply button. I have restarted Audacity and reinstalled Graillon. No change. Has anyone else run into this problem? Am I doing something wrong? (Entirely possible!). Many thanks for any assistance!
Where did you get that? I can only find the Graillon 2 Vocal Changer.
Have you tried changing the interface setting? Scroll to the bottom of the page to “Audio Unit Effect Options”. Under “User Interface” try “Generic”. Close the settings dialog, close the effect dialog then open the effect dialog again.
Upgrading to Audacity 2.4.2 might help.
– Bill
Ah, you’re right. It is listed as Voice Changer. I found it while looking for various free autotune options. I know Audacity has one as well. Thanks so much for responding so quickly!
So this issue is resolved for you?
– Bill
