Win 7 Home prem. 64bit.
I want to know if I can use Glaceverb in Audacity?
I think you’ll just have to try it. [u]Installing VST Plug-Ins[/u].
With free VSTs it’s usualy hit-or-miss. Most commercial VSTs list officially-compatible applications on their website, but most commercial VSTs don’t officially support Audacity (because most Audacity users don’t buy VSTs).
Thanks.
Is there any way to adjust the existing reverb effect as a track plays so it can be monitored instead if stop adjust stop adjust…?
Not yet. Any VST reverb plugin should support Audacity’s Real-time preview if you are using the current Audacity 2.1.2. Please see the pink panel at the top of the page to find out what version of Audacity you have.
If you want a simple recommendable VST reverb you can try Anwida Soft DX Reverb Light.
Thanks. I have 2.0.6
