Hello, I love using Audacity, and the only thing that would make it more awesome is using effect plugins, I’ve read that it now
supports VST so I wanted to use Softube’s VST but when I put the tube delay Plug-in folder in the plug-ins folder it doesn’t show up in the plug-ins Add/delete sub menu, are these not compatible with Audacity or is there a way of making them work?
Try the 32-bit version. Audacity for Windows is a 32-bit application and it only works with 32-bit plug-ins.
But it may not work because Softube does not officially support Audacity:
In theory, any 64-bit VST, VST3, AU, or AAX (11.0.2 or higher) compatible host application should work. However, due to plug-in host differences between DAWs - and our own rigorous testing standards - > we only officially test our plug-ins and instruments in the most recent versions of Pro Tools, Logic Pro, Cubase, Live, Studio One, Digital Performer, Reaper and Sonar. > Softube plugins are not tested in the non-listed systems, but they most likely work as long as the system requirements are met. We cannot guarantee a solution for issues in unsupported systems.
