I am editing recordings of a piano/trumpet album and need to use ReVerb or GVerb to create the illusion of a recording room with proper acoustics, but both are wiping out my audio after a part of one second. The length of audio clip does not change the out come.
Attached are three screen shots:
1: ReVerb settings
2: GVerb settings,
3: and the out come (being the same for both plug-ins).
What obvious things have I neglected?
kozikowski: There is no sound, but as you see a great deal of visual oscillation.
steve: I was using 2.0.2 at the project start. Just before posting to the forum I upgraded to 2.1.0 with the same results from GVerb and the new Reverb filter; thus my inquiry.
Gale Andrews: Yes, the results are the same no matter the file or file’s origin.
Okay, so it appears an FFMPEG package was not installed. I was looking through my downloads folder and it appears I was on the same track 3 years ago. That was before I started graduate school.
The package I found and installed is, “FFmpeg_v0.6.2_for_Audacity_on_OSX” and now both GVerb and Reverb fully function.
Should anyone else have this issue, I hope this helps. I sadly do not remember from where I downloaded the file.
'FFmpeg is used only for importing / exporting files, and by default it is only used for file types that are not natively supported by Audacity. I don’t see how this can be connected with the original problem that you reported, but I’m pleased that problem is no longer happening.
