In my internship my supervisor asked me to identify a audio format of a file.
After some researchs I’ve finally the informations on the picture attached.
This file seems to be a G.723.1. Is it co;pressed or uncompressed ? What can I do with it ? In which format can I convert it ?
I’m sure it’s compressed. There are only a handful of uncompressed formats. I think there’s only two lossless compressed formats. All the rest sacrifice some quality to get smaller files.
You can install the FFMpeg software add-on and open up many different sound formats. Once inside Audacity, you can export to any supported format.
