Hello and thanks for the ongoing upgrades to this outstanding software!
I’ve been using the real fx more than ever and have been frustrated assigning and re-assigning the same fx to let’s say, drums, vox or guitars, where each one is getting basically the same settings and i have to click thru and manually set each one…effects>compressor>presets & settings>drum control>adjust something(i know i can save presets but it’s the same process, minus the adjust something)> next track: effects>compressor>presets & settings>drum control>adjust something…when doing a lot of tracks on a lot of songs it gets tedious. Love to copy and past them
Until you have bus options.
Minor note- i’d love to have more than 4 colors for the track groupings. They don’t show when muted- could you be a lighter version of same color when muted? Unless there’s a reason i’m unaware of i think they should show always. Last thing! And when you amend a track that’s been designated red or whatever, it removes the color and you have to reset it but it won’t let you so you have to change it to another color and then back to the desired color.
thank you!!
