Functions under Tracks menu missing
What happened to all the functionality that used to be under the Tracks menu? It’s great to add new features, but why remove existing features?
The Mix and Render functions will be coming back. I don’t know about Align Tracks, Sort Tracks, Pan tracks and Mute tracks - I can’t find any Github issues relating to those.
Which functions in particular do you miss? If we’re lucky one of the devs might see this thread.
I have added them to Soundscaper , my Audacity 4 web version.
Do you know if these are on the roadmap (or whatever) for Audacity 4? Where would I look to find that out?
It’s entirely plausible that noone has thought about them because no ticket exists for them.
OK, I made one.
I’m using an older version, and I use Align Tracks a lot, along with Mix and Render. Sometimes I mute a track from the button on the left side of each track. Sort tracks is useful, too, if two tracks are imported and the wrong one is on top.
The reason I use these features is because I edit sermon audio files for my church’s website. I’ve found that Adobe Podcast is great about removing plosives and other noises as well as background noise. However, the free version of Adobe Podcast requires that the files be no longer than 30 minutes. Since the sermons are almost always over 30 minutes, I have to split them into two files, then upload them separately into Adobe Podcast. Then I import the “enhanced” files back into Audacity as two separate tracks and put them back together. So I have to first Align them End-to-End and then do Mix and Render to get them back into one track, then I do further editing in Audacity. I’m sure others have different uses for these same functions.
If you mix the Adobe Enhanced audio, with the original audio, the combination is more natural sounding. The two versions have to be perfectly in-sync though.
