Here’s what’s happened – clicking on anything just sounds an empty alarm. I can no longer do anything with my Audacity files. According to my former messages dated April 2015, I may be still using Audacity 2.0xxx. But I cannot find a download that over-writes it to use my files:
The link to older versions of Audacity is here: https://www.audacityteam.org/download/older-versions/
First you need to click the “Quit Audacity” button in the “Crash Recovery” dialog. Then cancel the “Update Audacity” dialog.
If that doesn’t help, go to the Apple menu, choose “Force quit”, then force quit Audacity.
Find Audacity in your Applications folder, click on it then choose File > Get Info. What is the version number?
