Freakshow Industries MISHBY Plug-In crash issue
Hello! I have an issue where I’ve put a VST plug-in called MISHBY into Audacity. It’s a really cool plug-in created by Freakshow Industries and can create some really bizarre and, for lack of a better word, cursed audio. However, whenever I try to apply it to a track, or have it as a live effect and go to hit export, Audacity always crashes, and I’m not exactly sure what to do. I try sending the crash report to audacity but it always fails to send, so I’m taking to the forums for help. I’m gonna put my crash report in a text file here, and perhaps someone could help me out, because I’m not even sure where to begin.
Crash Report.txt (156.9 KB)
I’m running the latest version of audacity, although this problem with MISHBY has persisted through previous versions as well. My Specs are as follows:
System Model - GS76 Stealth 11UG
System Type - x64-based PC
Processor - 11th Gen Intel(R) Core™ i9-11900H @ 2.50GHz, 2496 MHz, 8 Core(s), 16 Logical Processor(s)
Installed Physical Memory (RAM) - 32.0 GB
Graphics Card - NVIDIA GeForce RTX 3070 Laptop GPU
Hope any of this is helpful, thank you all!
Not all plug-ins support Audacity so it may not work.
This is from the Freakshow/MASHBY website:
Ditto. However their Dumpster Fire plugin works for me.
