Folder error opening
Please help, I used Audio city for the first time today and I saved a file then moved it to another folder but now it wont open! what can I do?
rror says @could not find the Project data folder’?
Audacity projects have two part:
  1. A “project file” that has a file name extension “.aup”
  2. A “project data folder” that has a name ending in “_data”
Both parts are essential.
You have moved the “project file” without the “project data folder”, so it is now not possible for Audacity to open the file because the “project data folder” is not there.
See: https://manual.audacityteam.org/man/audacity_projects.html
