I’ve used Audacity for several years to edit FLV files downloaded from BBC iPlayer. Each is around 30 minutes & plays without issue but when loaded into Audacity, they are truncated to around 6 minutes. This only seems to affect programmes downloaded after late October 2015. Has anyone else come across this issue?
I suspected that might be the case. I wish the BBC would edit the shows down to remove the padding (several minutes) at the start & end of shows. I listen to a lot of their shows when driving & I don’t want to be fiddling with my phone to skip the dross.
So in that case is it not some kind of Audacity issue? It would only be a DRM restriction if you could play the file in the iPlayer or some approved application but nowhere else.
