Trying to import a 2 hour FLAC file so I can convert it to WAV but it only imports the first 13 minutes
Try Kabuu Audio Converter. (Sorry, Window only.)
Are you sure it’s all there? Is it 2-hours in Windows Media Player, or whatever you normally use? You can also check it with MediaInfoOnline.
Yes its all there
There might be something wrong with the file. I had no problem importing a 2 hour FLAC file into Audacity.
You could try xAct.
Are you running out of room? We should remember that FLAC is a lossless compressed format and Audacity internally converts everything to super high quality, uncompressed. So it’s totally not going to be two hours worth of data inside Audacity. It’s going to be much larger.
Are you doing all your work on your internal drive?
I know this is almost a stupid joke, but have you shut down your Mac and started it again? Even if your transfer doesn’t start working, did the problem change?
Plenty of space on my drive and tried restarting my Mac with no luck.
Ended up trying MediaHuman audio converter which worked for now, so no idea what the problem is with Audacity but any help would still be appreciated
Will it open in Audacity after you converted it?
Yep fully imports after I converted it to WAV
