I am new to using Audacity. I am looking for some fixes to a vinyl click which elevates the immediate subsequent signals to ride on the decaying click. Currently, I perform piecewise normalization of the elevated signal, and use repair to smooth out the transition between each piece. Conceptually, it should be a simple fix to drag down the elevated signal to the baseline. Is there such a plug-in?
Works like a charm. Thanks. The last time I learned about Nyquist plots was half a century ago, for control systems. This Nyquist plugin is easier to understand, and more practical.
