Greetings.
So the problem now is not the message “another copy of Audacity is running”, but that Audacity takes a long time to launch? Is that correct?
Indeed, now the problem is the response time audacuty. Before the title problem was much less time.
Roughly how long does it take for Audacity to launch?
Audacity takes about 23 seconds to start.
Try launching Audacity from a terminal window (open a terminal window and type > audacity> )
When you press “Enter” you should see a lot of text appear while Audacity is scanning for these things. Copy and paste that text into your reply - that should give some idea what is taking the time
I started Audacity from a terminal and the text is as follows:
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2217:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib audio/pcm_bluetooth.c:1614:(audioservice_expect) BT_GET_CAPABILITIES failed : Erro de Entrada/saída(5)
ALSA lib pcm_dmix.c:957:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
Cannot connect to server socket err = Non hai tal ficheiro ou directorio
jack server is not running or cannot be started
Expression 'ret' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1670
Expression 'AlsaOpen( &alsaApi->baseHostApiRep, params, streamDir, &self->pcm )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 1830
Expression 'PaAlsaStreamComponent_Initialize( &self->capture, alsaApi, inParams, StreamDirection_In, NULL != callback )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2092
Expression 'PaAlsaStream_Initialize( stream, alsaHostApi, inputParameters, outputParameters, sampleRate, framesPerBuffer, callback, streamFlags, userData )' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 2764
Expression 'stream->playback.pcm' failed in 'src/hostapi/alsa/pa_linux_alsa.c', line: 4541
ALSA lib pcm_dsnoop.c:612:(snd_pcm_dsnoop_open) unable to open slave
The language of my system is Galician and there are parts of the text are translated. But I think you should understand without problems.
Thank you.
