In the upper left I have the Filter Curve EQ just how I like it.
When I take the “-dB” slider down to -120dB I get the image on the upper right, which you can see has gone askew on the vertical axis.
In the bottom you can see when I slide the “-dB” back to -10 dB the curve has gone way askew on the vertical axis.
The dB slider is ostensibly useful for fine tuning. This is no bueno. Should I create and save the preset without touching the “dB” slider at all?
But then I run into another problem: when I reset Filter Curve EQ to factory default the dB slider defaults do NOT reset. This is a problem when you use different presets with different dB slider values, when you can see they go askew.
What dB slider levels should I choose BEFORE I create?
After seeing this how can I really believe the filter curve settings?
