Files open with pitch/tempo settings applied?!
Ever since I updated to Audacity 3.6, I’ve found that often when I import an audio file, the pitch/tempo settings have been automatically adjusted. I’m guessing that’s a feature for people working on music projects, to automatically keep clips in the same key/tempo. Most of the time, I’m working on sound effects, for which this doesn’t make any sense, and it’s driving me crazy!
Is there some way to disable that feature, whatever it is?
Can anybody help?
What file types are you opening?
