jtcan
March 29, 2024, 3:35am
1
I am unable to export files, I get “unable to create destination folder.” I installed the FFmpeg following the instructions, still the same.
I think ffmpeg should not make any difference in this case. Where do you want to export to - your internal drive or an external one? And at what location on that drive?
You can try to create a folder at the desired location first (using the finder’s “New folder” command) and then select this as your desination. Does this work?
That’s a little too fuzzy.
What’s the show? Why are you doing this? Where are you trying to put the files? Can you export to the desktop?
This appears to be this bug:
opened 01:22PM - 13 Dec 23 UTC
closed 10:47AM - 29 Mar 24 UTC
bug
P4
import-export
Design Debt
> I’ve noticed that since the 3.4 update (I believe), the export audio dialogue … box now doesn’t allow me to create a new folder in the “Folder” path if the path seems to be more than 1 folder deeper than the current folder.
> For example, if the path is set to C:\export
> I can create C:\export\export
> But I cannot create C:\export\export\a
> In this case, Audacity has the error of “Unable to create destination folder”
Original report from https://forum.audacityteam.org/t/bug-or-error-when-trying-to-make-new-folder-when-exporting-audio/92959/
The workaround here is to use the browse dialog instead to create the folders.
It’ll be fixed in Audacity 3.5.
system
Closed
April 28, 2024, 3:36am
6
