FFmpeg Not Found
I got that message, but I have already installed both types of libraries onto my computer
HELP!
Please see http://manual.audacityteam.org/o/man/faq_installation_and_plug_ins.html#macff for how to install the FFmpeg libraries.
I have been using Audacity forever and just recently started having the exact same issue. I am running yosemite 10.10.5 and audacity 2.1.1 I have the FFmpeg file in the audacity library folder and audacity will not find the codec I went through all the recommended steps, also I redownloaded the libraries in zip form and also dmg file and attempted to manually find the codec after installing them in different places and even though i find the codec and click on it audacity still says not detected, I haven’t tried working with m4a since upgrading to yosemite until just recently and that seems to be the only change. I can still import m4a but i cannot export. Any help on this issue would be greatly appreciated! Thanks!
The help is in the link already provided Audacity Manual. FFmpeg is usually detected by Audacity on Yosemite and Mavericks without problem, if you follow those steps.
To diagnose any problems we would need to see the log from Help > Show Log… .
You may find it easier to export as WAV or AIFF then convert to M4A in iTunes. See Audacity Manual.
picture of help log
http://i242.photobucket.com/albums/ff107/soto6nine/Screen%20Shot%202015-09-01%20at%207.28.33%20AM_zps40yr60yt.png
also here is a youtube video of my desktop of me trying to load the file it is about 47 seconds
https://youtu.be/IfSUy4JIWEs
As it says in the link and on the buanzo download page, you need FFmpeg 2.2.2 for Audacity 2.0.6 or later, not FFmpeg 0.6.2. http://lame3.buanzo.com.ar/ffmpeg-mac-2.2.2.zip or http://lame3.buanzo.com.ar/ffmpeg-mac-2.2.2.dmg.
sorry to be a pain =) but even with the ffmpeg 2.2.2 like i said when i manually try to load the codec it for some reason will not load
21:27:47: Audacity 2.1.1
21:27:47: Trying to load FFmpeg libraries...
21:27:47: mLibAVFormatPath ('/Applications/Audacity/audacity/libavcodec.52.dylib') is not empty. Loading from it.
21:27:47: Checking for monolithic avformat from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:47: avformat not monolithic
21:27:47: Loading avutil from '/Applications/Audacity/audacity/libavutil.50.dylib'.
21:27:47: Loading avcodec from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:47: Loading avformat from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:47: Actual avutil path /Applications/Audacity/audacity/libavutil.50.dylib
21:27:47: Actual avcodec path /Applications/Audacity/audacity/libavcodec.52.dylib
21:27:47: Error: dlsym(0xa526360, avformat_version): symbol not found
21:27:47: Actual avformat path
21:27:47: Importing symbols...
21:27:47: Error: Failed to load symbol av_register_all
21:27:47: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:47: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:47: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.55.dylib, 1): image not found
21:27:47: Loading avutil from ''.
21:27:47: Error: dlopen(.bundle, 1): image not found
21:27:47: Loading avcodec from ''.
21:27:47: Loading avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:47: Error: Failed to load FFmpeg libraries.
21:27:47: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:47: Checking for monolithic avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:47: Error: dlopen(/usr/local/lib/audacity/libavformat.55.dylib, 1): image not found
21:27:47: Loading avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:47: Trying to load FFmpeg libraries from system paths. File name is 'libavformat.55.dylib'.
21:27:47: Checking for monolithic avformat from 'libavformat.55.dylib'.
21:27:47: Error: dlopen(libavformat.55.dylib, 1): image not found
21:27:47: Loading avformat from 'libavformat.55.dylib'.
21:27:47: Error: Failed to find compatible FFmpeg libraries.
21:27:57: Attempting to load LAME from system search paths
21:27:57: Loading LAME from libmp3lame.dylib
21:27:57: Actual LAME path /usr/lib/libmp3lame.dylib
21:27:57: Error: dlsym(0x109102f0, lame_get_lametag_frame): symbol not found
21:27:57: LAME library successfully loaded
21:27:58: Trying to load FFmpeg libraries...
21:27:58: mLibAVFormatPath ('/Applications/Audacity/audacity/libavcodec.52.dylib') is not empty. Loading from it.
21:27:58: Checking for monolithic avformat from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:58: avformat not monolithic
21:27:58: Loading avutil from '/Applications/Audacity/audacity/libavutil.50.dylib'.
21:27:58: Loading avcodec from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:58: Loading avformat from '/Applications/Audacity/audacity/libavcodec.52.dylib'.
21:27:58: Actual avutil path /Applications/Audacity/audacity/libavutil.50.dylib
21:27:58: Actual avcodec path /Applications/Audacity/audacity/libavcodec.52.dylib
21:27:58: Error: dlsym(0x17a9690, avformat_version): symbol not found
21:27:58: Actual avformat path
21:27:58: Importing symbols...
21:27:58: Error: Failed to load symbol av_register_all
21:27:58: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:58: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:58: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.55.dylib, 1): image not found
21:27:58: Loading avutil from ''.
21:27:58: Error: dlopen(.bundle, 1): image not found
21:27:58: Loading avcodec from ''.
21:27:58: Loading avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:27:58: Error: Failed to load FFmpeg libraries.
21:27:58: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:58: Checking for monolithic avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:58: Error: dlopen(/usr/local/lib/audacity/libavformat.55.dylib, 1): image not found
21:27:58: Loading avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:27:58: Trying to load FFmpeg libraries from system paths. File name is 'libavformat.55.dylib'.
21:27:58: Checking for monolithic avformat from 'libavformat.55.dylib'.
21:27:58: Error: dlopen(libavformat.55.dylib, 1): image not found
21:27:58: Loading avformat from 'libavformat.55.dylib'.
21:27:58: Error: Failed to find compatible FFmpeg libraries.
21:27:58: Looking for FFmpeg libraries...
21:28:22: User-specified path = '/Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib'
21:28:22: User-specified FFmpeg file exists. Success.
21:28:22: Trying to load FFmpeg libraries...
21:28:22: mLibAVFormatPath ('/Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib') is not empty. Loading from it.
21:28:22: Checking for monolithic avformat from '/Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib'.
21:28:23: avformat not monolithic
21:28:23: Loading avutil from '/Users/Alex/Desktop/ffmpeg-mac-2.2.2/./libavutil.52.dylib'.
21:28:23: Loading avcodec from '/Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib'.
21:28:23: Loading avformat from '/Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib'.
21:28:23: Actual avutil path /Users/Alex/Desktop/ffmpeg-mac-2.2.2/./libavutil.52.dylib
21:28:23: Actual avcodec path /Users/Alex/Desktop/ffmpeg-mac-2.2.2/libavcodec.55.dylib
21:28:23: Error: dlsym(0x283cf90, avformat_version): symbol not found
21:28:23: Actual avformat path
21:28:23: Importing symbols...
21:28:23: Error: Failed to load symbol av_register_all
21:28:23: Trying to load FFmpeg libraries from default path, '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:28:23: Checking for monolithic avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:28:23: Error: dlopen(/Library/Application Support/audacity/libs/libavformat.55.dylib, 1): image not found
21:28:23: Loading avutil from ''.
21:28:23: Error: dlopen(.bundle, 1): image not found
21:28:23: Loading avcodec from ''.
21:28:23: Loading avformat from '/Library/Application Support/audacity/libs/libavformat.55.dylib'.
21:28:23: Error: Failed to load FFmpeg libraries.
21:28:23: Trying to load FFmpeg libraries from legacy path, '/usr/local/lib/audacity/libavformat.55.dylib'.
21:28:23: Checking for monolithic avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:28:23: Error: dlopen(/usr/local/lib/audacity/libavformat.55.dylib, 1): image not found
21:28:23: Loading avformat from '/usr/local/lib/audacity/libavformat.55.dylib'.
21:28:23: Trying to load FFmpeg libraries from system paths. File name is 'libavformat.55.dylib'.
21:28:23: Checking for monolithic avformat from 'libavformat.55.dylib'.
21:28:23: Error: dlopen(libavformat.55.dylib, 1): image not found
21:28:23: Loading avformat from 'libavformat.55.dylib'.
21:28:23: Error: Failed to find compatible FFmpeg libraries.
In FFmpeg 2.2.2, avutil should be “avutil-52.dylib”, avcodec should be “avcodec-55.dylib” and avformat should be “avformat-55.dylib”. The libav* versions you are loading belong to older FFmpeg.
So it comes down to the same thing, you either have to use only FFmpeg 2.2.2, or export as WAV and convert to M4A in iTunes.
If you want to use FFmpeg, delete all the libav* files that you have now in Applications/Audacity/audacity/.
Then if you believe you had actually downloaded FFmpeg 2.2.2, clear the downloads list or cache in your download manager or web browser and download FFmpeg 2.2.2 again.
