It’s been mentioned in other posts about this issue but the solution doesn’t work for me.
My Audacity log shows this:
09:24:31 PM: Audacity 2.0.6
09:24:31 PM: Trying to load FFmpeg libraries...
09:24:31 PM: mLibAVFormatPath ('C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll') is not empty. Loading from it.
09:24:31 PM: Looking up PATH environment variable...
09:24:31 PM: PATH = 'C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Smart Projects\IsoBuster;C:\Program Files (x86)\Windows Kits\8.0\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static'
09:24:31 PM: Checking that 'C:\Program Files (x86)\FFmpeg for Audacity' is in PATH...
09:24:31 PM: Warning: FFmpeg directory 'C:\Program Files (x86)\FFmpeg for Audacity' is not in PATH.
09:24:31 PM: Temporarily appending ';C:\Program Files (x86)\FFmpeg for Audacity' to PATH...
09:24:31 PM: Checking for monolithic avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
09:24:31 PM: Error: Failed to load shared library 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll' (error 5: access is denied.)
09:24:31 PM: Loading avutil from ''.
09:24:31 PM: Error: Failed to load shared library '.dll' (error 5: access is denied.)
09:24:31 PM: Loading avcodec from ''.
09:24:31 PM: Loading avformat from 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
09:24:31 PM: Returning PATH to previous setting...
09:24:31 PM: Error: Failed to load FFmpeg libraries.
09:24:31 PM: Trying to load FFmpeg libraries from default path, 'C:\Program Files (x86)\FFmpeg for Audacity\avformat-55.dll'.
09:24:31 PM: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
09:24:31 PM: Checking that '' is in PATH...
09:24:31 PM: FFmpeg directory is in PATH.
09:24:31 PM: Checking for monolithic avformat from 'avformat-55.dll'.
09:24:31 PM: Error: Failed to load shared library 'avformat-55.dll' (error 5: access is denied.)
09:24:31 PM: Loading avformat from 'avformat-55.dll'.
09:24:31 PM: Error: Failed to find compatible FFmpeg libraries.
I’m getting access is denied for avformat-55.dll, and audacity shows it as not found. However LAME 3.99.3 shows as found ok. Both folders have the exactly same permissions as each other.
I’m on Windows 10, although I can’t remember if this is the first time I’ve tried audacity since upgrading to Windows 10 so I’m not sure if its to do with that.
Any ideas?
